Author: Subject: Centre-Lock Wheels
posted on 8/9/08 at 07:40 PM Reply With Quote
Centre-Lock Wheels
What are the pro's?
Worth the hassle of converting a 'normal' hub?
PS - Also have a thread about push-rod suspension on the go too if you want to contribute
novacaine
posted on 8/9/08 at 07:48 PM Reply With Quote
i cant imagine there are many benefits other than the look
that is unless you want to go do some F1 style pit stops
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
posted on 8/9/08 at 08:00 PM Reply With Quote
Nah - I have a set of centre-lock mag rims kicking about. So light that I thought I might try to use them (if engineering a new hub wasn't too costly / difficult).
blakep82
posted on 8/9/08 at 08:26 PM Reply With Quote
i'd imagine making new hubs would be a bit of a nightmare... and sourcing a wheel nut to suit. i think radical may use something thatcould help, but not cheap. i seem to remember 1 wheel nut being about £45.
________________________
posted on 8/9/08 at 08:34 PM Reply With Quote
Eeek... I draw the line at £45 nuts!
blakep82
posted on 8/9/08 at 08:41 PM Reply With Quote
ah, there you go http://secure2.cyberware.co.uk/~rad-shop/acatalog/sr8wheelstyres.html
£36 each... plus vat no doubt.
sure you could probably find them somewhere cheaper, its the only place i could think of that you might get them though
[Edited on 8/9/08 by blakep82]
posted on 8/9/08 at 08:52 PM Reply With Quote
Cheers... will look into it!
ReMan
posted on 8/9/08 at 10:22 PM Reply With Quote
Pick up a new engine while you are there
http://secure2.cyberware.co.uk/~rad-shop/acatalog/sr8engineancillaries.html
mcerd1
posted on 9/9/08 at 08:34 AM Reply With Quote
this is going to be some car when you've finished it
I guess Sid could make you a set of hubs if you know exactly what you need
posted on 9/9/08 at 10:39 AM Reply With Quote
Cheers mcerd1.
I'm focusing on things that makes the car go, stop and turn better, rather than a lot of the fancy (read expensive and IMHO unnecessary) gizmo's that a lot of Ultima owners fit to their cars.
I guess I'm building the worlds only locost Ultima by choosing my parts carefully and recycling components where possible!
When you say Sid.... do you mean Sid Winters?
mcerd1
posted on 9/9/08 at 11:29 AM Reply With Quote
yes, Sid's your man for 1 off machining round here
this latest bit he's done for mine,
it just needs polished up and anodised now
but then again are there any centrelock hubs that would fit off the shelf ? (or with minor mods)
[Edited on 9/9/08 by mcerd1]
posted on 9/9/08 at 01:25 PM Reply With Quote
Oooooh... very nice!
Who are you using for anodising?
PS - were you able to make any use of the Lotus seats?
mcerd1
posted on 9/9/08 at 05:08 PM Reply With Quote
anodising - I've been putting together batches with another Dax owner and he's been taking them to a place near him (down manchester way)
I can get you the details if you like, but if you've just got a couple of bits you could throw them in with mine
the next batch will be hard anodised (black only, and it might not be very shiny, but it will be hard)
I've not done anything with the seats yet, I'm still miles off that bit (btw - you don't have the old covers do you ?)
posted on 11/9/08 at 08:24 PM Reply With Quote
I think I may have, but they've gone mouldy as they were in a shed with a leak in it!
mcerd1
posted on 12/9/08 at 12:43 PM Reply With Quote
I'd still take them if you've got them, I'm only wanting to make a pattern from them
