Author: Subject: fuel pipe
dunk3
posted on 12/9/08 at 06:49 PM Reply With Quote
fuel pipe
hi everyone . can any one tell me what size fuel pipe i need for my mk indy zetec build .does it have to be rubber or copper and whats the gap for the p clips for sva purposes,
posted on 12/9/08 at 06:53 PM Reply With Quote
8mm pipe. My preferred choice is copper pipe in the transmission tunnel with rubber at either end. Make sure the rubber pipe is stamped as fuel pipe and has the necessary BS codes. Copper pipe can be any old 8mm microbore plumbing pipe from B+Q
Can't remember the clip spacings but it's in the manual (RTFM!!!) and that's available all over the shop online as a PDF (useful to have for the build).
adam1985
posted on 12/9/08 at 07:29 PM Reply With Quote
i used 10mm copper pipe on mine cant remember what the clips gaps were think 100mm or could of been 150mm but someone else will confirm this im sure do the clip gaps need be the same for cables
adithorp
posted on 12/9/08 at 08:40 PM Reply With Quote
SVA manuual doesn't specify spacing for fuel pipe. Just says securely attached. It says 300mm max for wiring loom fastnings though.
adrian
http://jpsc.org.uk/forum/
posted on 12/9/08 at 09:22 PM Reply With Quote
Bugger!!! That's me giving bad advice then sorry.....
