chris_smith
| posted on 28/9/08 at 05:50 PM |
is this an escort axle??
as above, i was told this is an escort but unless im having a blonde day i cant figure out how the slave cylinder goes on
please help!!!
andylancaster3000
| posted on 28/9/08 at 05:55 PM |
Thats the wrong wheel cylinder by the looks of things. The cylinder you have is for the 9" drums where as those back-plates are 8" ones.
andylancaster3000
| posted on 28/9/08 at 05:58 PM |
You need something along the lines of these for those backplates. :
http://cgi.ebay.co.uk/PAIR-OF-WHEEL-CYLINDERS-FOR-FORD-ESCORT-ROVER-MARINA_W0QQitemZ160280378849QQcmdZViewItem?hash=item160280378849&_trkparms=72%
3A1301|39%3A1|66%3A2|65%3A12|240%3A1318&_trksid=p3286.c0.m14#ebayphotohosting
There are a number of different cylinder internal diameters to choose from depending upon which spec car they are for. I believe these can be found in
the escort haynes manuals.
theconrodkid
| posted on 28/9/08 at 06:12 PM |
the back plates look like mk 2 escort with floating cylinders and self adjusters,the cylinder looks like mk 1 with manual adjusters
who cares who wins
pass the pork pies
| posted on 28/9/08 at 07:52 PM |
The back plates are Mark 1 Escort with 8" drums ie 1100/1300
The wheel cylinder is the wrong type it's off a mk2
The correct wheel cylinder is the same as fitted to the Triumph Herald, Viva, Imp and various other small British cars.
It is held in by two U shaped clips that interlock (the clips are a male and female).
This allows the wheel cylinder to slide in slot of the backplate.
http://www.rimmerbros.co.uk/herald/22a.htx
[Edited on 28/9/08 by britishtrident]
| posted on 28/9/08 at 07:54 PM |
no the other way about
| posted on 28/9/08 at 07:57 PM |
Other thing is I think you will find the backplates are fitted to the wrong side of the car -- ie switched left to right.
chris_smith
| posted on 28/9/08 at 08:03 PM |
im getting the feeling i should be converting to sierra discs
