Surrey Dave
| posted on 28/9/08 at 09:36 PM |
Eezibleed or Vacuum Brake Bleeder?
What the pro's and con's are they both effective?
mookaloid
| posted on 28/9/08 at 09:43 PM |
not used a vacuum bleeder but I've had an Eezibleed for years and it's great.
Mark
tomgregory2000
| posted on 28/9/08 at 09:51 PM |
second vote for eezibleed, its soooo easy
tommy
tegwin
| posted on 28/9/08 at 10:05 PM |
Vacum bleaders tend to suck air in from around the nipples etc... (ooh er matron)...
Use an ezibleed pressuized system
www.verticalhorizonsmedia.tv
mark chandler
| posted on 28/9/08 at 10:07 PM |
Vacumn for me, eezibleed needs a really good seal on the brake pot or it fills it to the brim with fluid, its also eezi to spray fluid around.
Vacumn negates this but you have to keep the resevior topped up and its best to seal the bleed nipple with some copper ease grease before you start
sucking.
You can of course go the old way, gravity, assistant, jam jar and a bit of rubber hose, which just takes a bit longer but is free.
[Edited on 28/9/08 by mark chandler]
les g
| posted on 29/9/08 at 12:12 AM |
easy bleed any time just dont have the tyre pressure set to high
i,ve used it on everything from trucks and buses to cars
les g
mad-butcher
| posted on 29/9/08 at 08:59 AM |
same as les, easy bleed for me works atreat on transits
Tony
| posted on 29/9/08 at 09:55 AM |
Easzibleed -- everytime problem with vacuum bleeding is it can draw air into the system past the master cylindr seals particularly on Teeves systems
-- also easzibleed is cheeaper.
Remember even with an Eazibleed you need to give the master cyilnder at least a couple of pumps to get any trapped air out the mastercylinder.
loggyboy
| posted on 29/9/08 at 10:04 AM |
i would vote for EZ, but as ive not used a vacuum set up it wouldnt be a very fair vote. However when i have used the EZ system its been quick and
effective. Providing you have a compressor to keep refilling ur spare tyre. (especially if your doing a bleed from comprehensive line change so theres
lots of bleeding to do!)
Mistral Motorsport
| posted on 29/9/08 at 05:38 PM |
I have used both and my vote goes to the Easibleed or better still the Sykes pressure bleeder with built in air pressure regulator
| posted on 29/9/08 at 07:56 PM |
Easibleed can work very well, as long as you take care to set it up properly. Screw the wrong cap on, or don't bother checking the seal and you
and your car's paint are in for a good dousing in brake fluid.
I changed the hoses on my Fiat Coupe at the weekend and Easibleed made bleeding the calipers a two minute job, and didn't involve a large
argument with SWMBO.
