Author: Subject: do i need a breather in my axle?
blakep82
posted on 6/10/08 at 10:24 PM Reply With Quote
just realised i haven't got one... hmmm
i can always weld/bolt something into the back cover.
its a atlas axle by the way, or at least the diff casing used to be... not much else is now
________________________
C10CoryM
posted on 7/10/08 at 02:09 AM Reply With Quote
Yes. Gases inside expand as they get hot with sufficient pressure to blow your axle seals. Best get a breather on there.
"Our watchword evermore shall be: The Maple Leaf Forever!"
Danozeman
posted on 7/10/08 at 05:34 AM Reply With Quote
Is there not a hole for one already?
Dan
blakep82
posted on 7/10/08 at 07:19 AM Reply With Quote
well the axle was re tubed, and i didn't think about iit. i've seen back covers with tubes coming out, so i guess i can weld a peice of tube or half of a steel tube connector in the back cover
adithorp
posted on 7/10/08 at 11:43 AM Reply With Quote
If you do that then make sure it isn't where there will be oil splash or you'll just leak oil.
adrian
http://jpsc.org.uk/forum/
