Author: Subject: where might i find one of these?!
blakep82
posted on 11/10/08 at 12:59 PM Reply With Quote
they're only small, for an axle breather.
the picture's from gartrac, but at £10 each....
[Edited on 11/10/08 by blakep82]
________________________
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 11/10/08 at 01:33 PM Reply With Quote
Any idea what thread size you need?
Wonderous is our great blue ship that sails around the mighty sun, and joy to everyone that rides along!
adithorp
posted on 11/10/08 at 01:38 PM Reply With Quote
Somewhere like EuroHydralics?
adrian
http://jpsc.org.uk/forum/
blakep82
posted on 11/10/08 at 01:42 PM Reply With Quote
not really needing the thread. its for a axle breather tube. i'm going to weld it into the back cover of my atlas axle
Liam
posted on 11/10/08 at 01:47 PM Reply With Quote
RS
Liam
posted on 11/10/08 at 01:48 PM Reply With Quote
Or haven't you got a small piece of tube you can weld on? No pressure so no real need for the barb.
Liam
blakep82
posted on 11/10/08 at 01:54 PM Reply With Quote
true enough^ i was thinking one of those so i could clip a peice of tube to it easy enough and looks proper too, but you're right a peice of tube would work. just thought they looked nicer. my axle can't actually be seen you see
zilspeed
For search purposes, it's called a hose barb.
My LPG system uses them where the output of the injectors goes onto the inlet manifold.
blakep82
posted on 11/10/08 at 01:56 PM Reply With Quote
ah! LPG, of course. think i know somewhere nearby where i can get one
r1_pete
posted on 11/10/08 at 02:52 PM Reply With Quote
This would look ok screwed in.....
Mark G
posted on 11/10/08 at 03:57 PM Reply With Quote
can't you just use a brake bleed nipple?
jacko
posted on 11/10/08 at 04:44 PM Reply With Quote
Air line parts ?
posted on 11/10/08 at 05:37 PM Reply With Quote
looks very much like the fitting that screw into facet pumps. available for 6 mm and 8 mm hose.
look at FSE (fuel Systems enterprise) they sell them, ..... but check they are steel as if they are brass (which I think they are), you cannot weld but solder sholuld work too.
locost way would be to weld in a piece of steel tube and attach a host with jubilee - it won;t blow off as there should be very little pressure being a breather.
RichardK
posted on 11/10/08 at 06:20 PM Reply With Quote
What about an air compressor fitting??
Rich
Gallery updated 11/01/2011
