les g
posted on 18/10/08 at 11:15 AM |
44mm od tube/pipe
i need some 44mm od pipe tube
steel
carb to manifold plate
anybody know where to buy a short length
cheers les g
[Edited on 18/10/08 by les g]
zilspeed
posted on 18/10/08 at 11:24 AM |
Aluminium ?
Scaffold
Steel ?
Oh no - that means buying, money and stuff.
big_wasa
posted on 18/10/08 at 01:36 PM |
steel Scaffold tupe is ideal for the zetec port size but its about 50m O/d.
I turned a few mm of with the lathe.
But it was free ![](/images//smilies/bigsmile.gif)
les g
posted on 18/10/08 at 04:05 PM |
sorry !!!
steel please
wasa i know you used scaffol pipe but the carbs are 44mm odthat would be hell of a strtchy bit of rubber i would need
les g
Hugh Paterson
posted on 18/10/08 at 04:20 PM |
Hi les will have a decko in the workshop in the morning see what i have on the rack u might be jammy with an offcut, failing that can whack a bit off
to size with the lathe if u cant get any close to home
Shug.
big_wasa
posted on 18/10/08 at 05:41 PM |
1 3/4" tube is 44.45 mm O/D ,get some with a 1.5mm wall and it will be close for the port size.
Any "good" steel stock holder or on ebay link
Hugh Paterson
posted on 19/10/08 at 04:15 PM |
steel tube
Hi les, u got u2u chum
