Author: Subject: Suspension Idea <OT>
chrisf
posted on 22/10/08 at 12:59 PM Reply With Quote
Hi gents:
This is a bit off topic, but you guys have been more than helpful in the past. I hope this is no bother...
OK, so I'm building my wife a MX-5/Miata powered MG Midget (check the website for details). I'm going to try to stay with the stock rear axle and 1/2 elliptic leaft springs--yes, a buggy suspension. Anyway, to control lateral movement, I'm considering the following.
MG Midget Suspension Idea
The green lines are the proposed links to control lateral movement of the axle. What are your thoughts on this? Will this idea work OK or should I bite the bullet and design a panhard bar?
Understand this car is for my wife to dash out with friends for shopping, wine, etc.; it's not going to be a roadracer. The Miata engine only has 120 hp and was selected for the fuel injection and reliabilty--nothing more.
Again, apologies for the off-topic question.
--Thanks, Chris
Mr Whippy
posted on 22/10/08 at 01:08 PM Reply With Quote
I don't think I'd do that as the distance between the axle and the chassis will change as the springs compress, that will pull on the twin link bar and probably cause the axle to rotate, also make the bushes wear out very fast. You can use double links with trailing arm suspension. If you are finding a lot of lateral movement then check the sping bushes for wear, ususally the springs stop sideways movement.
chrisf
posted on 22/10/08 at 01:14 PM Reply With Quote
Hi:
I should have stated this car has never been driven--by me anyway, so I'm just predicting lateral movement. All the bushings in the leaf springs will be replaced with poly.
So what if I used rod ends on each side of the link? Same issue?
--thanks, chris
mookaloid
posted on 22/10/08 at 01:17 PM Reply With Quote
I agree with the above - I didn't think there was a problem with the rear suspension on a midget anyway - maybe go for improved shockers to tighten things up and maybe slightly wider wheels and tyres if they will fit.
The power may not be much from the mazda engine but it's nearly double what the midget had originally, so I would make sure that the brakes are up to the job and that the rest of the suspension is in tip top condition.
Mark
tegwin
Why do you want to add the bars?
The standard rear suspension setup would be adequate to stop lateral movement....
If you want to make it more "interesting" convert it to IRS...I know of several cars that this has been done to
www.verticalhorizonsmedia.tv
Mr Whippy
posted on 22/10/08 at 01:22 PM Reply With Quote
well having thrashed the life out a friends midget showning him how to drift roundabouts sideways. I can tell you lateral movement is not an issue. It'll be noisy mind with the poly bushes and you'll really hear the diff whine like you need a new one. Put grease in the bolt before fitting as poly bushes squeak
also the brakes suck
[Edited on 22/10/08 by Mr Whippy]
chrisf
posted on 22/10/08 at 01:42 PM Reply With Quote
Thanks Gents! That is actually encouraging news. I dreaded f-ing around with controling lateral movement.
I have a rubber bumper car with the 4x4 ride height. I plan on dropping it 2" all round. Is this a bad idea? I figured the chrome bumper cars rolled out of the factory 1.5" lower than the rubber bumper cars. So what's the harm in dropping it another 1/2"?
Oh, I lost the rubber bumpers and I'm doing sheetmetal work to convert it back to CB specs. I'll also look to replace the brakes And I'm doing telescoping shocks as well--front and rear. Those lever arms seems like an awful idea.
--Thanks, Chris
[Edited on 22/10/08 by chrisf]
Mr Whippy
posted on 22/10/08 at 01:55 PM Reply With Quote
I'd say fit the new dampers then try it out on the road and see what you think before guessing what you need. They have normally got quite soft suspension so I found it bottomed out quite easly on country roads, which is what they were designed for after all.
HAL 1
Builder
Posts 226
Registered 5/2/06
Location bolton
Member Is Offline
Photo Archive Go!
Building: Built haldane 100, retirement project Marcos GT
posted on 22/10/08 at 02:24 PM Reply With Quote
I once owned 'B'GT with rubber bumpers, after some heavy use the rear springs sagged so i just replaced the front ones with chrome type to bring it down a bit, seemed to work ok.
could be worth asking around with regard to replacing springs, the ride height was only for U S regs and i doubt whether B L spent vast amounts on re-development of the bodyshell
posted on 22/10/08 at 02:37 PM Reply With Quote
The 1/2 eliptic rear suspension is a lot better than the earlier 1/4 eliptic, but still suffers from the same issues as most Hotchkiss type arrangments i.e. axle tramp and location. A panhrad rod and anti- tramp bars would be a wise addition to any tuned Midget IMO. They are available through e.g. MOSS, but are rather expensive for what you get. However, it would be quite simple to replicate the design yourself.
The other addition I would consider is a front damper conversion kit. The standard lever arm damper doubles as the upper wishbone, and to say it's rather flimsy is putting it nicely. A proper upper wishbone conversion and telescopic dampers really help calm down the Midgets nervousness.
EDIT: Just read you are ditching them anyway!
[Edited on 22/10/08 by MikeRJ]
Memphis Twin
posted on 22/10/08 at 04:38 PM Reply With Quote
Chris,
The twin radius arms as per your drawing would work very well. I would Rose joint one end and rubber bush the other.
I once hillclimbed a Sylva Leader kitcar with a similar arrangement for lateral axle location. It worked just as effectively as a panhard rod arrangement, except perhaps off the line with sticky tyres, where it wasn't quite as good at controlling the torque reaction of the axle. But I'm just splitting hairs there...you'd probably never notice the difference. I would go ahead and do it, and I'm speaking from experience.
Cheers Chris.
posted on 22/10/08 at 07:16 PM Reply With Quote
Looking at that I diagram reckon the first thing you need to do is find a wider axle or fit some wheel spacers!
Actually the more I think about it, the more I think a panhard rod would be a superior solution all round. Compressing the elliptical springs will cause the axle to move backwards (which is why one end of the spring needs a shackle), and those links will be trying to resist that motion and will cause binding if they are mounted in the same plane as the springs on the bottom of the axle.
If they were mounted on the top of the axle then they would give you the benefit of some anti-tramp, but you'd have to get the mounting points in the right place to prevent the whole axle rotating in bump and droop. This would be simmilar to the later Cortina rear axle location, and it's still over constrained (i.e. causes binding). This is fixed in the Cortina by rubber void bushes (which used to fail regularly).
