Author: Subject: Steering/Trackrod Q
speedyxjs
posted on 24/10/08 at 08:24 AM Reply With Quote
Steering/Trackrod Q
I brought a reconed pug manual steering rack without track rod ends off the bay which came yesterday.
Now the threads on the end of the pug rack are on the inside of the track rods wheras the threads on the jaguar track rods are on the outside.
I know you are not allowed to weld them so would it be ok to cut the threads off the jag rack and screw them (if they fit) onto the pug ones?
Im sure this will only make sense to me
eznfrank
posted on 24/10/08 at 08:28 AM Reply With Quote
Most use extension pieces on shortened racks anyway so dont' see how that is any different to having a female/female connection piece?
But......what's wrong with the pug ones?
speedyxjs
posted on 24/10/08 at 08:29 AM Reply With Quote
Dont have them but would they not be too small?
ETA - Im using Jag hubs
[Edited on 24-10-08 by speedyxjs]
posted on 24/10/08 at 09:35 AM Reply With Quote
I have no problem with that - no different to regular extensions - check first that the threads are compatible:diameter/pitch/handedness.
You will need a half nut if one of the parts does have thread exposed.
posted on 25/10/08 at 06:29 PM Reply With Quote
Arm your steering arms ahead of the wheel centres or behind ?
