blakep82
| posted on 26/10/08 at 02:14 PM |
caliper mounting plate thickness?
what thickness plate should i be looking at to make caliper mountings from?
is 6mm too small? should i be looking more 8-10mm?
________________________
big_wasa
| posted on 26/10/08 at 02:26 PM |
6mm should be fine
| posted on 26/10/08 at 02:38 PM |
Core diameter of one of the bolts would give at least equal strength to the mounting bolts (which is over kill).
Also twisting moment to consider so at least 8mm -- perhaps 10mm
[Edited on 26/10/08 by britishtrident]
MkII
| posted on 26/10/08 at 03:39 PM |
my rear caliper brackets are 8mm if that helps.m.
blakep82
| posted on 26/10/08 at 03:44 PM |
hmm, how do you mean?do you mean core diameter of 1 bolt will be at least equal to the plate?
think i might go 10mm then. better to over engineer things rather than stick with the minimum. 10mm makes things harder to work with though will
take hours with the hacksaw lol
Echidna
| posted on 26/10/08 at 03:46 PM |
And too much blades!
blakep82
| posted on 1/11/08 at 01:05 AM |
what if i was to use 6mm and fillet it too? or 8mm?
i'm thinking 10mm might not give a great weld penetration on my welder. i'm thinking 6mm should be fine, and the fillet will give the
stiffness it needs?
| posted on 1/11/08 at 08:40 AM |
http://cgi.ebay.co.uk/English-Axle-Disc-Brake-Brackets_W0QQitemZ330280718564QQcmdZViewItem?hash=item330280718564&_trksid=p3286.c0.m14&_trkparm
s=72%3A1301|66%3A2|65%3A12|39%3A1|240%3A1318
blakep82
| posted on 1/11/08 at 09:29 AM |
^ hmmm 6mm...
well, 6mm it is, plus fillets can be welded it if needed i guess
blakep82
| posted on 1/11/08 at 01:01 PM |
what diameter is the english axle tube? is it 70mm? his brackets look like they might be a perfect fit without mods...
