big_wasa
| posted on 29/10/08 at 09:14 PM |
Hydraulic brake light switch.
I am running a twin master cylinder with bias bar set up.
Does the switch want to go in the back line or front for the best operating presure ?
Having done a search some say back others say front.
cheers
hearbear
| posted on 29/10/08 at 09:30 PM |
Yep front
wicket
| posted on 29/10/08 at 09:34 PM |
In the back as it fitted in with the rest of the wiring.
locoR1
| posted on 29/10/08 at 09:35 PM |
Hi mate
Just my personal opinion but i would have to say in the front line due to the higher pressure but that's not from experience so we will have to
see what others say.
Check out my CB500T Cafe Racer build diary
omega 24 v6
| posted on 29/10/08 at 09:38 PM |
Front as it's a bias box. Basically there will always be more pressure in the front line. If you put it in the rear line then under very light
braking it may not even come on depending on what pressure it's set at. I'm sure someone on her had problems with it in the rear
before
TOO BADD
| posted on 29/10/08 at 09:49 PM |
I have bias twin cylinder and its in the front
lsdweb
| posted on 29/10/08 at 10:27 PM |
Front. And you can use a banjo bolt switch which makes
the installation really nice!
Wyn
| posted on 30/10/08 at 08:12 AM |
To be 100% legal it should be the front --- largely forgotten part of the old road traffic acts.
procomp
| posted on 30/10/08 at 08:40 AM |
Hi.
As Wyn has ^^^ said the banjo bolt switches are very good. As for the other more common type if you use one from the range of older MG's etc
they will work fine in both the front and also in the rear of the rear brake line they work with light pressure. Also there is a 4 way T piece from
that range of cars which makes mounting the switch easier than breaking into a line elsewhere. ( Is it possible to have a 4 way T piece. You know
what i mean )
Unlike some of the racers who fit the ones that need very high pressure to work but can be made to work to pass a scrutineer by standing on the brake
pedal. Mind you they tend to change them when other drivers keep running up the back off them .
Cheers Matt
rumplitter
| posted on 30/10/08 at 10:35 AM |
pic of banjo bolt in use?
anyone got a pic of banjo bolt in use?
http://www.locostbuilders.co.uk/upload/MiniMojoProject.JPG
DarrenW
| posted on 30/10/08 at 10:51 AM |
Ive fitted t piece type switch in rear line and it doesnt work well. Probs better in front. Ive since learnt that there are different pressure
switches available. Apparently series 2 land rovers use the lower pressure switch (only know about land rovers as my mate repairs them).
Mix
| posted on 30/10/08 at 04:29 PM |
Hi
Slightly off topic but is it no longer permissable to have a microswitch activated by the motion of the brake pedal?
Regards Mick
lsdweb
| posted on 30/10/08 at 07:07 PM |
Banjo fitting - here - scroll down to SAE Brake Adapter banjo
fittings and Metric Brake Adapter banjo fittings
Wyn
omega 24 v6
| posted on 30/10/08 at 07:23 PM |
I'll let you know as it's the way I've done it Mick.
Sva before the end of the year I hope.
big_wasa
| posted on 30/10/08 at 08:19 PM |
cheers all
| posted on 1/11/08 at 07:35 PM |
quote: Originally posted by Mix
Hi
Regards Mick
Standard way of operating the brake lights since the 1970s I would advise using an automotive brake light switch rather than a standard
microswitch.
You can also get pulll operated brake light switches
http://www.completeautomobilist.com/parts/auto%20electrical/switch/
