lsdweb
posted on 30/10/08 at 02:40 PM |
BEC Engine Position?
Hi All
My Westfield chassis has just gone off to MVS for repair and all the mods. I was looking at it yesterday and wondering how far back I can place the R1
engine. I'm tempted to shorten the passenger footwell (it'll probably never carry a passenger!) and get the engine back as much as
possible. I haven't measured yet so don't know if the driver's footwell would prevent this anyway.
I was wondering if anybody else has done this - lots of the BECs I see have the engine quite a long way forward of the 'normal' sideways
chassis member.
Regards
Wyn
lightspear27
posted on 30/10/08 at 03:03 PM |
Wyn
Place the engine where the passenger use to be
gingerprince
posted on 30/10/08 at 03:13 PM |
Close. Place the second engine where the passenger used to be
matt_claydon
posted on 30/10/08 at 04:36 PM |
Surely a BEC is already tail-heavy with driver and tank of fuel (very much so with passenger too), I woudn't have thought there would be any
benefit getting weight any further back.
motorcycle_mayhem
posted on 30/10/08 at 04:41 PM |
I've found it a question of balance. Even when hanging my GSXR750 in the 'usual' Westfield position, it's difficult to get the
corner weights right. The heavier GSXR1300 did balance out though.
IF I wasn't held off by the regulations 'engine must be in the same position and orientation as originally specified by the
manufacturer' - it would be exactly where the passenger should sit, with a short shaft/coupling to the diff.
I did this with the Clan, had the 'Blade mounted right alongside the driver, pipes amusingly exiting the passenger door. The induction roar was
an ear-bleeding experience, even with plugs and a helmet.
But, went, handled beautifully.
mark chandler
posted on 30/10/08 at 06:14 PM |
Mines got a shortened passenger footwell.
Although the chassis is upside down in the picture you can see I took advantage of this by increasing the triangulation across the engine bay.
My only regret is that I could have come back an extra 2" more with the engine.
Regards Mark
mark chandler
posted on 30/10/08 at 06:17 PM |
I should add, I grew the driver footwell in width, later r1 engines are also shorter as they have stacked the gearbox to allow for a longer swinging
arm.
[Edited on 30/10/08 by mark chandler]
