brakes
A1 - 1/8/08 at 12:18 PM
do you need a brake servo for indys? i wouldnt have thought so cause its so light, but thought id better check.
JohnN - 1/8/08 at 12:18 PM
no
Mr Whippy - 1/8/08 at 12:22 PM
no again
mackei23b - 1/8/08 at 12:52 PM
and no again!
82 Locost - 1/8/08 at 12:53 PM
No
gingerprince - 1/8/08 at 12:59 PM
narp
Nosbod - 1/8/08 at 01:02 PM
nay, nay and .... thrice nay
Bluemoon - 1/8/08 at 01:04 PM
As it's friday.. One more "helpful" post
No..
Dan
worX - 1/8/08 at 01:29 PM
nie
indykid - 1/8/08 at 02:18 PM
no
thebull - 1/8/08 at 02:53 PM
and its a no again
britishtrident - 1/8/08 at 03:17 PM
Not as simple as that !
Yes an indy is half the weight of a sierra but you run into a problem with lack of pedal leverage.
For reasonable pedal pressure you need a non-servo (smaller bore) master cylinder.
Westfield use a 0.7" bore master cylinder, Sierra master cylinders are 0.81" or 0.84" bore.
Been covered many times.
Bluemoon - 1/8/08 at 03:25 PM
O.k only if you site the pivot as low as possible.. British trident, it's a good point, most overlook... I wish that MK would put the master cylinder about 10cm lower than they do it would make the ratio about right (5:1 ish)..
Dan
[Edited on 1/8/08 by Bluemoon]
Hellfire - 1/8/08 at 03:29 PM
Dan
If they did that your heel would be scraping on the floor... we have a Sierra MC and all is well - the fr/rr bias is great too (we have no bias valve) with disc's on't rear's.
Maradona - 1/8/08 at 03:30 PM
Nop, the race cars not use servo.
FASTdan - 6/8/08 at 12:01 PM
yes....just to be different!
FASTdan - 6/8/08 at 12:04 PM
Thats interesting to know as I have a rear disc set up from an XR4x4 I was thinking of adding but was unsure of bias complications.
