which brake calipers
brashhighlander - 29/12/06 at 12:17 AM
I have a set of brake calipers from a xr4x4 and a 1.8 sierra the difference being either 260mm or 240mm discs. I will have to admit the larger discs do look much better but for a 7, however I know I don't really need large discs,
So what are the nest calipers to use for a locost and what discs? Also I can get another set or sierra calipers and solid disks.
Which set up do you recommend.
zxrlocost - 29/12/06 at 12:21 AM
the non vented will be plenty enough and also lighter so there you go
brashhighlander - 29/12/06 at 12:31 AM
Thats what I thought, I just liked the look of the larger calipers
robinj66 - 29/12/06 at 08:57 AM
If you're looking for new Sierra calipers, try something like this
http://cgi.ebay.co.uk/FORD-SIERRA-82-87-BRAKE-CALIPER-WITH-SOLID-DISCS_W0QQitemZ200032955013QQihZ010QQcategoryZ21654QQrdZ1QQssPageNameZWD1VQQcmdZViewI tem
NTDWM
