Hi all, just to let you know....
Failed on:-
Couple of edges inside and out - easy fixes (sponge and edge strip).
Front indicators too far from edge - rear track wider than front, i was hoping to get away with it...
Trackrod ends need better protection, i had used foam - he wanted to see those plasticky things on ebay.
Brake bias too far to rear on two readings, and not pinned (obviously not going to do that until it passes)
Speedo out - i had forgotten my speedohealer instructions, he gave me an opportunity to get it right but couldn't in the time available....
EMISSIONS!!! readings were:-
First fast idle -
CO 0.05 Pass
HC 18 Pass
Lambda 1.15 Fail
Second fast idle -
CO 0.55 Fail
HC 22 Pass
Lambda 1.04 Fail (just)
Natural idle -
CO 0.86 Fail
Think it's running too lean, fuel pressure a bit low - 38psi but i think i need 43psi??
Last thing was rear axle design weight, Luego figures were 500 - with me in it it was 500.68!!! Bit harsh?? I need to diet....
Soooooo....could have been worse, got the retest booked for two weeks tomorrow which was the earliest test date available.
Russel the tester seemed a nice enough bloke though, is a biker too!
Going for a pint now.....
Rich.
Rich,
bad luck with the knock back. At least you know what needs sorting to get through next time. I've just been through my second, and the guy was
really laid back about the mods i had done to sort the radiusing problems etc. he didn't even chaeck with the spheres etc. we just went over the
car quickly - i pointed out what i had done and he nodded after a quick glance.
have you booked up your retest?
alex
Cheers, mate. Yes, retest two weeks tomorrow so plenty of time in hand. Was expecting a fail but still stings a bit...
i know how you feel - i'm sure a curry and a few beers will help later!!
"Track wider at back tahn front?"
Eh?
"rear axle design weight, Luego figures were 500" How do the figure a custom Axle?
They measure the lighting 400mm in from the widest point on the vehicle, that's what he means, not a problem with the track being wider at the
rear.
Seat belts OK then ? I know you were worried about them .
Aye, the belts got through no problem!!! Can't believe it.....
Bolts fitted lovely - nice one.
been for a pint - feel slightly better now!!
I was building my hopes up that you were driving it down my place this weekend.
So was I....
where you welsh boyos from, i was in school with a richard thomas its not you is it?
bad luck on the sva ill be going to cardiff, isn't it in ponty though??
I'm in maesteg mate, right up them valleys...isn't it.
The sva place is behind corner park garage just off the m4 at the llantrisant junction.
Rich.
not too bad , tester is a nice bloke ,Lyn ring me if you need them bits this weekend Lenny
Thanks for that run out today Len, i'm still grinning
.....got my modded fuel rail tonight - busy day tomorrow!!
Rich.
