MNR Lower harness mounts
vinny1275 - 7/2/09 at 04:43 PM
Hi all,
quick question about the lower harness mounts - the MNR chassis has gusset plates mounted at the back for bolting harnesses to - the bracket for the harnesses on the outside mount doesn't clear one of the chassis tubes tho. Is it OK to pack them up with washers to clear the tube? (It only needs a few mm under the swivel mount thing).
Vince
jacko - 7/2/09 at 05:09 PM
Thats what i would do
Did you get some little tubes like top hats ? if so they should go in between the bracket and seat belt
