As title, i have tried super glue and bike puncture repair glue and neither have worked and i dont have anyother glue to try.
What have you used to sick it on?
Tommy
not sure exactly what sort of insulation you are using but would some sort of shrink wrap hold it on ok?
if its just for lagging pipes then tape
i need to fit about 1" of it on a fibreglass surface
Contact adhesive (solvent free). Nice and easy to remove post SVA too
Aberdeen SVA Center told me to remove the pipe lagging off of the front suspension arms before the test because it was obvious that that was tempoary.
Even though it was held on with cable ties. (promptly failed on sharp edges front suspension........:mad
To hold pip lagin to pipes slip over pipe and then wrap some tape (electrical or duck tape) round the outside.
[Edited on 4/303/09 by mad4x4]
gaffa tape is all i ever use for evrything
