Hello all, looking to re-do the interior of my car at some stage and one of the things I want to do is change my harnesses. The ones I have are 4
point, but have the shoulder straps fixed to the waist strap and it is a pain to get in and out of! So, where is the best place to get 4 point
harnesses that all 4 points can be undone, to aid getting in and out?
Lee
I like my Luke ones...
When I up-grade mine to wider ones I'm going for pull-up lap straps.
IIRC Securon in Amersham can do those to special order.
Cheers, Pewe
Willans Harness are nice I have those in mine, go for the 3" wide ones as they dont cut in and have a neat aviation style turn buckle in the
middle. They can also take another point if you want a crotch strap for racing or track days and com in a lovely blue colour.
Stockbridge racing make them and although they are not cheap they are bloody comfy.
In the seven I have sabelt 4 points, the adjustment can be a bit fiddly around the waist as you tighten by pulling away from you. I'm a tight
squeeze in the car so its awkward getting them really tight without removing them and rebuckling them.
However they are 3", very comfortable and were a reasonable price. They are also handed so as not to scratch the side of your car with the
buckle.
In the fury I went for Scroth Profi II harness which have adjusters that can be set to pull or push to tighten, also have a nice buckle, and are very
comfortable.
The Sabelt ones i bought at stoneleigh direct from Sabelt, and the scroth harnesses I got from MSAR Safety who were very friendly on the phone.
TRS ones in mine from Jam.
Adjusting the waist is a bit fiddly but once its right just moving the seat back a notch loosens them off.
I second the Willans Harnesses, by Stockbridge Racing in - wait for it - Stockbridge! They make them for everyone you have ever heard of in racing and aren't that far from you. Excellent service (while you wait if you want) but not cheap!
