I am looking for 1 (or possibly 2) used 50mm 7/16" UNF harness eye bolts as supplied by Willans as in pic below.
Harness Eye Bolt
Due to an SVA fail on the harness upper harness mounts being too low I have installed lower seats and I am raising the seat belt mounts by 20mm with
spacers. Problem is one of the the eyes has had the thread shortened to about 25mm which doesn't leave enough thread to engage in the threaded
part of the mounting.
I could buy a new one but ideally want a used one as after some persuasion the SVA tester accepted that the eyes, which have no markings, were
supplied by the harness manufacturer and were therefore SVA ok and I want something to match the others.
Alternatively I could buy a new set with the correct markings but I thought I would try here first.
Nick
Thanks big_wasa but my concern is if I replace one with a correctly marked new eye then the tester may question the integrity of the other 3 unmarked
ones.
I was hoping someone might have an odd Willans eye to match.
If not I will just replace all 4 with correctly marked ones.
