Rear view Mirror?
scooby_doo_do - 28/4/10 at 06:31 AM
Looking at taking the windscreen off this weekend and putting an aeroscreen on.
I'm trying to find a relativly cheap rear view mirror (in carbon if possible) with a single bolt fixing (i've found a hole already made - so guessing it had one on in the past) - any pointers on where i can get one from?
Craig.
Hugh_ - 28/4/10 at 06:50 AM
http://www.rallydesign.co.uk/product_info.php?cPath=1728_1738&products_id=15229
I have one of these, with the 3 hole base attached to the scuttle and a single hole through the aeroscreen which also gives it a bit more support.
Worzey - 28/4/10 at 07:00 AM
I use the RaceTech interior mirror. Small, light and a single bolt.
Linky
BenB - 28/4/10 at 07:43 AM
Do you need one? Most scuttle mounted rear view mirrors are a bit poxy (ie don't actually give much of a view).
I find a "driving lesson" style wide view mirror on a sucker is better than most because of the very wide angle of vision. Otherwise with the RVM's I've tried I just had a nice view of a small bit of my roll bar Even the wide angle jobby is a bit marginal when you've taken into account the view being blocked by seats / passengers / roll bars / high level brake lights. The main reason I keep mine on is incase it turns out I need one if I get stopped by the rozzers!
