To all who have fitted Triton seats :-
Bearing in mind IVA requirements, what is the recommended height above lower chassis rails for fixing these seats? What vertical spacing did other
users of these seats employ?
Already have 2 chassis rails in place for seat mounting, so cannot use the steel floor (although I don't reckon that would provide sufficient
shear strength).
Will read your comments with much interest.
You want to fit them as low as you possibley can, there is an allowance in the seat for fitting runners without raising the height.
For IVA you will need to fit edge trim but as per SVA it depends where yu go as they differ...
You will also have to make sure your top belt mounts on your chassis align with the upper slots on the seats.
Hope that helps..
Mark
Thanks for your reply. I guess you should know all the measures needed.
Trial fit tomorrow.
