Something isnt quite right with the seating/steering position on the car
After much head scratching, i think the pedals are too far forward - i.e too near the driver
Could someone measure the relationship between the pedal footpad, and the bulkhead line?
Also, how far from the back of the footwell are the pedal pads?
Thanks!
What car are you building? Is it a kit or a Locost or a Roadster etc.
Some photos of your pedals and seating position etc. might help to illustrate where the problem is.
i had that problem but when i read the instructions properly from the guy i bought the kit off, it says to cut a few mm of the master cylinders thread
i can`t remember how much you have to cut off but am sure someone on here will know or you could ask steve at Aries motorsports!!
i hope this helps!!
Will take some pics on monday and post them....
if u could post how much that would be appreciated.
