is anyone on here able to work and cut ally for mounting clocks and switches?
i ideally want something 8-10 mm thick as long as can pass the radius test, it will be rectangular in shape but will have a semi circular cut out for
clocks and 3 small rectangles for swtches
I would have thought any laser cutting place could do it for you.
purdy would do it mj engineering currently building mk for customer
A 10mm thick ali dash???
Make it in 3mm, or thinner if you can brace it behind.
A good engineering shop should be able to roll a 19mm radius on the bottom for you.
Daniel - do we understand right that you want to make an entire 1 piece dash out of 10mm thick ally?
That will cost a rather large wad to get the material alone, never mind getting it machined, finished (anodised) and fitted.
...or do you mean an insert panel to fit into/behind a GRP/Carbon dash panel?
I don't think the entire dash is going to be made from 10mm ali
sounds like a little centre console type thang....
i made my ali dash from 3mm.....
10mm is mahooosive!!!
just a small rectangular section with a cut out for my clocks. will 3mm be sturdy enough?
Ample and much easier to get hold and work with. Water jet or laser profiling would be an easy job, but it really wouldn't be hard to do manually with hole saws/files etc.
