Hi,
Does anyone know where I can get a top-hat piece for the lower mount of seat belts? The piece to allow the bolt to be done up tight but allow some
movement in the belt.
James
Scrap yard.
scrap yards your best bet. i have some kicking about i think. Do you just want 1?
this is the only one i could find i little pricey if you only need the spacer
http://cgi.ebay.co.uk/SEAT-BELT-BOLT-NUT-STRESS-PLATE-SPACER-WASHER-/130415535255?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1
e5d5f2497
Can't you make something up with different sized washers all drilled out to the same inside diameter?
Or, as already suggested, just go to a scrapyard.
