how have you guys mounted the threaded eye bolts for the lower harness mounts? i have the trs harnesses with clip on mounting buckles but i dont fancy just bolting the eye bolts to the to the ali floor!
threaded bush welded to the chasis, I have seen people recommend photoghraphing the way the mounts are fitted for IVA purposed. These have to be
substantial mounts as the forces applied upon impact are massive
[Edited on 17/11/10 by austin man]
Does the MNR chassis not have lower belt mounts welded into the chassis?
No lower mounting points on the Mnr chassis
Sorry to hijack, but can lower anti dive belts be bought ???
if so were, as i may need a couple !!
Regards
Here you go
Originally posted by Johneturbo
Here you go
Here you go
isn't that still 2 plates short though?
Ditto with what Adrian said
it has those small steel plates welded in but they are only very thin (2-3 mm) and i dont want to use them as my only protection. any other options?
what you need to do is when you buy your harneses also buy these to sit under
will be fine unless you weigh 50stone!?
the steel plates are for the harnesses
you think about how much force you'd require to brake them.. sheesh
[Edited on 18/11/10 by Johneturbo]
thanks mate! where can i buy a couple of pairs? they will do nicely.
I bought mine from sabelt uk, when i also got my harnesses
try
HERE
thanks mate. very helpful!
