How much of the wiring loom should be on display when the scuttle is fitted?i have fitted switches and speedo and alot of the wiring loom is on
dispay.pics would be helpfull.
Cheers Chris
In the cab area i don't have any wires on show in the engine bay there is some but not a lot
Jacko
[Edited on 30/12/10 by jacko]
cheers jacko,dont if i should relocate the loom now,bit of a big job thou.
chris
you shouldn't really have any of it showing... engine bay is fine, but behind the dash, it shouldn't really be visible. that said, mine will have to run along the floor on the passenger side, and brake lines on the drivers side. insode the tunnel is filled with exhaust, and heat insulated fuel lines
