Is there such a thing as a 90 degree bent seatbelt eye bolt?
Due to space issues, I need the thread to be at right angles to the eye.
Thanks in advance
I don't think so, and you wouldn't want to use anything that wasn't designed for the purpose.
Can you not just use bolted fixings for the belts instead of clip-on?
Yes I could but I have a set of clip on belts. Are you suggesting to bolt with a big washer through the clip on fitting?
I have a similar problem to you but only with the passenger. A bit of a lack of leg room for them
For 'harnesses', but not seabelts:
http://www.liftingsafety.co.uk/product/swivel-eye-bolt-2297.html
top hat spacer for belt to swivel on,bolted from above
A clip on belt will not go over a 7/16" bolt.
