5th / 6th point harness mount
thefreak - 13/7/11 at 09:18 AM
Looking to convert my 4 points to 5 points now as dont want to have any submarining excursions
First issue will be cutting a hole into the seats...
http://img.photobucket.com/albums/v65/thefreak/Freakyparts/MX5/IMG_4660-1024.jpg
I'm guessing mark up, masking tape, close eyes and prey?
Then I'll need a point for the harness. Will something like this work?
Harness eye bolt backing plate FIA approved | eBay UK
Is the usual idea just to clean up the floor and weld it directly onto it? or mount from underneath with a suitable hole drilled or what? Any tips?
James - 13/7/11 at 02:05 PM
I appreciate the desire to avoid submarining... I bought seats with a hole for 5/6 point to help avoid this myself.
But! Having seen those photos of the rally driver who hit a tree, didn't have the 5/6 points tightened correctly and 'burst' his 'ahem' groin region.... I'm slightly more recitent to actually order the harnesses!
But atleast the hole in the seat lets the rain out!
James
thefreak - 13/7/11 at 02:26 PM
Hmm... I see what you're saying.
I guess it's a toss up between busted balls or mangled spine.. I wonder if you can still get it up when you've mangled the spine...
I'm hoping (aren't we all) not to have that sort of incident where trees/rally speeds/heavy impact is involved, as it's only a baby MX5
Johneturbo - 13/7/11 at 02:29 PM
James
ouch!
It's something i've thought about (not bursting my you know whats) i do find the 4 points always wanting to rise up, and having a shiney slippery fibreglass seat won't help.
I guess just a solid fixing on the chassis will do the job
ETA That plate is what i've got for my lower 4 point fixings on the car, its the same as Sabelt supply with their harnesses
on mine it just sits under a 3mm plate that is part of the mnr chassis design
[Edited on 13/7/11 by Johneturbo]
blakep82 - 13/7/11 at 02:32 PM
i thought the spreader plate just bolted on underneath (no need to weld) but i would want to see something a bit thicker than the normal floor fixed to the top of the floor too
my chassis has two 5mm thick steel plates welded to the top of the chassis tubes, and the floor fixed to the bottom of the tubes
nick205 - 13/7/11 at 02:33 PM
I always wished I'd gone for 5 point harnesses in my old Indy. The trouble with 4 point harnesses is that you can't get the shoulder straps tight enough without pulling the lap straps up your midriff. I never felt fully comfortable myself.
I'd say the risk of burst gentleman jewels is very liveable in relation to the potential damage caused by submarining.
thefreak - 13/7/11 at 02:35 PM
That's both my problem and my reasoning. The harness sits around my hips/waist comfortably without the shoulders attached, as soon as they're tight, the buckle is making it's way north to my stomach, leaving plenty of room for me to head south in the event of a decent shunt.
David Jenkins - 13/7/11 at 02:35 PM
Perhaps 6-point would be more 'man-friendly'? They're fastened across the top of your thigh, so as long as you keep the family jewels neatly arranged between the straps then all should be OK...
...but I'm only guessing!
The other problem with a 4-point is that the waist belt rises up - not so much the submarining problem, more that the impact will be taken over soft tissue which would be extremely damaging (possibly terminal), instead of across your pelvis.
[Edited on 13/7/11 by David Jenkins]
RK - 19/7/11 at 11:45 AM
Being an mx5 owner, you won't have family jewels to worry about, will you?
Sorry, that was rude...
daviep - 19/7/11 at 11:51 AM
thefreak - 19/7/11 at 11:58 AM
Blah blah blah
Neeeaaawwwwmmmmm
A lot of fun on the track for a lot less than most cars. For <£1k you cant get a 7 on the road doing the same
[Edited on 19-7-11 by thefreak]
RK - 20/7/11 at 02:28 AM
Yes I am reminded that they are better value every time I go to autoslalom... but then I come to my senses.
BTW they are not cheap in Canada. You can't get a decent one without rust for less than $3500 (and high mileage).
thefreak - 20/7/11 at 06:16 AM
I've just bought a second for £500 that's now going to be the Exocet donor
