Does anyone know if this is suitable for gel-backed carpets to ali panels?
Cheers!
i would not have thought so, PVA tends to bond well to porus material and ali isnt very porus, i could be compleatly wrong however since i have never
tryed it
tilly
PVA won't dry, use contact adhesive
but do test some on a small sample of the carpet & gel to see it is compatible first
[Edited on 26/8/11 by Mr Whippy]
My kids were using PVA to stick sea shells to paper the other day when they were making collages and it worked amazingly well!
It also dries clear so won't look a mess.
I would have thought it would work well on carpet to Ali. It is cheap enough to have a go on a cut off.
Stu
PVA won't form a good bond to metal.
As already suggested contact adhesive ----- Evostick.
You could also try a hot glue gun.
Thanks people!
Just a tip with contact adhesive on ally, give the ally a quick dusting with etch primer a few hours before spraying the adhesive, makes it stick sooo much better
As above PVA needs the water to escape to dry so metal is a no no, re contact adhesives we have found the stuff from Wickes/ Screwfix to be just as
good as the original evo stik. hth
Mike
I ended up using the Alpha stuff from Woolies. Not cheap at £24 a litre (VAT and delivery inclusive), but it works well!
