Hi has anyone got an Koso rx2n on the car and pass an IVA test with it? if yes can you send me some pic please of where you put it and how you mounted it. thx
Meeee...
It causes no bother at all from memory.
FYI ive just been kindly reminded that you need to fit a bus size steering wheel(Sierra from memory) for it to pass confidently....
"It does however cause lots of problems, every edge is non compliant ie requires 2.5 mm radius. Obviously your car was IVA'd with standard
steering wheel, therefore only part of the clocks was non compliant because some of the clock fell within the steering wheel exclusion zone ie.
steering wheel dia + 127 mm."
so because part of the clock fell in to the exclusion zone it was ok to pass? i just want to be clear as i want to do a very similar layout to you and
i dont want to waste another dash. thanks
[Edited on 1/3/12 by RMarine]
Replied to your u2u mate
Hi, Ive not passed IVA yet (sent the forms off this week) but
here is how I've mounted my Rx2n.
Lee
thx guys
