Hi Guys,
I'm trying to find out which instrument panel I have before taking the dashboard apart. The previous owner mentioned the donor vehicle was a 1979
2.0 Cortina (some bits off a Sierra) but when I've searched google, all pics look different to mine
I'm asuming its one complete panel under the dashboard cover but I could be wrong.
If anyone can help that would be great!
[Edited on 20/9/12 by markie76]
Capri I beleive
Capri is the correct answer
Nice execution
Capri is the correct answer![]()
i third capri
wow that is a small steering wheel
Slightly Off Topic but is it possible to use something like these donor instruments with a later engine.
I'm using a Zetec engine, MT75 Gearbox and MegaJolt ignition. To reduce cocts could I sensibly hook these up to something like the Capri panel?
How would the tacho get it's feed?
John.
Tacho is proabably they easiest to sort, its just a pulsing signal that on older non ecu engined car would be fed from the -ve connector on the coil, but on ecu cars theres a signal direct from the ecu, the signals are largely the same. (accept if you get a set of dials from a 6cyl capri, which would expect a signal 1/6th as fast.
Originally posted by loggyboy
Capri I beleive
I'm using a Zetec engine, MT75 Gearbox and MegaJolt ignition. To reduce cocts could I sensibly hook these up to something like the Capri panel? How would the tacho get it's feed?
John.
Just wondering if anyone has a wiring diagram for this instrument panel (or any capri panel) they would be willing to scan and share with me? Or if
anyone has a Capri Haynes manual a scan of the diagram would be great!
I need to rectify/install;
* the instrument panel backlights
* fuel guage doesn't seem to be working
Might be to early but theres a loom diagram here:
http://www.rigsofrods.com/threads/88183-71-Ford-Capri-2-0-build
Might be worth a scan through some of these too
google image search
[Edited on 17-10-12 by loggyboy]
