How do you measure the correct size harness for your car?
My current harnesses have seen better days and creep, so i'm looking to replace them and just wanted to know how you should measure them. I know
I could measure the current ones, but want to make sure that they were right in the first place.
I have just bought some harnesses from prima motorsport, when ordering mark @ prima asked me to measure the following:
Lap strap- Harness mounting point to the centre of the quick release (belly button) when sitting in the car
Shoulder strap- Harness mounting point to adjuster (nipples)
I must say I'm delighted with the harnesses and primas (Mark/Tessa) customer service is fantastic, I ordered on the Thursday received the
harnesses on Tuesday made to measure and fitted perfectly
http://www.primamotorsport.com/
Would these be Sabelts?
I had a sheet from TRS when i ordered mine, it has everything on they need to make the belts. Even if you use a different make it should help you in
measuring the right things.
it's on a PDF, so if you want it U2U me your email addy and i'll fire it over
cheers
Duncan
[Edited on 9/5/13 by Duncan36]
Hi guys,
Cheers for all the replies and for the u2u messages.
Duncan,
If u would that would be excellent. I'll send u a u2u now :-)
