Hi guys,
I'm wanting to buy some harnesses for my westfield, now I've heard a few people say that they've failed IVA because they were hard to
adjust, which kind do I need suitable for upcoming IVA, I would prefer aircraft style and also approved for racing. Any recommendations?
Thanks,
Dean
I used Securon type B passed IVA easily, the
examiner liked the fact they are very easy to adjust, simply pull the strap up to tighten
http://www.primamotorsport.com/prima_motorsport_products/kit_car/kit_car_harness.html vosa approved, aircraft buckle and made to measure.
I got two securon type D harnesses new from eBay for £62.50. Lap strap as type is pull towards you to ideal for a kit.
Eta from this eBay seller. http://myworld.ebay.co.uk/automotive_parts_warehouse?ssPageName=ADME:L:OC:GB:1181
Had to put in best offer and that was what they accepted.
[Edited on 10/6/13 by theduck]
Prima Motorsport did a lot of work with VOSA, to ensure that FIA approval was an IVA pass
get ones that are FIA approved and you can't go far wrong.
the ease of adjustment thing could cause an issue i guess, if you have to pull the straps down for example, but the transmission tunnel is in the way
for example, like mine is...
I've just got new Sabelt harnesses direct from Steve at Sabelt and couldn't recommend him enough!
