Any idea if i can get a child seat that will work with a full harness
Cheers Ali
You could probably make one work. But as for one off the shelf? No chance.
Its quite obvious where you are going with this!!
It all depends on how much you value the child!!
Seriously though, depending on age of child and the mods you happy to make to the car.
I would consider fitting a standard lap and diag or making and fitting an ISO style mounting.
If it is for a 7 I found that any booster seat lifted the kids up making them more vulnerable.
The law is a bit vague on what is required, but I think the best option is just get the harness done up nice and tight, and use your common sense to
check they seem safe.
I wouldn't take my kids in the car if they were really small though.
The law is a bit vague on what is required, but I think the best option is just get the harness done up nice and tight, and use your common sense to check they seem safe.
My nephews second boy spends all his time with me in the workshop sitting in the car and i have given him little rides round the village he is
desperate to go with me and i have no problem with keeping him safe but would like to keep within the law thanks for the valid points and keep them
comming.
Cheers ALI
If you are concerned about legality, then you cannot modify the booster seat in any way for it to remain type approved. For my daughter I bought a simple booster (like the one linked above), which was an expanded polystyrene block with a fabric cover. I made a fitting it sat on to locate it on the cushion of the seat just so it wouldn’t slide around before doing up the 4 point harness. It worked well enough, but ultimately got cracked by being stood on one time too many.
We got a polystyrene booster which is meant to go between two other child seats, so it's a bit slimmer and fits in the westfield race seats
nicely.
I put my boy in it at the weekend to test fit (he's 6, as a guide to his size) and it seemed to be ok. Then I grabbed his ankles and gave a
slight tug forwards, which dragged him down the harness and we could see that with any major force the only place he'd stop would be his neck on
the lap belt.
On the plus side, I now have a carrot to dangle so we see clean plates at every meal time, but he won't be going out in the car any time soon...
I made my half brother in law wait till he was 13 before I felt he was tall enough to not slide down and out of the 4 pointer.. to which I agree the
lap belt meets the neck.
a mate has had is son driving around in is avon from 9, but he has a 3 point belt.. Is far more suited to kids and seemed safe enough from a keeping
him in the seat point of view.
I bought a cheap, but CE marked, polystyrene child seat from Makro for £15. I took the cover off and trimmed the polystyrene so it fitted tightly into
the fibreglass seat and put the cover back on. When belted in and the straps adjusted nice and tight, my boy was more secure then he ever is in the
ISO-FIX seats we have in out tin-tops!
I had no worries about taking him out for a ride in the car.
Amazing what folk used to get away with what passed for "safe"
http://hollywoodsgarage.ca/wp/wp-content/uploads/2013/03/childseat.jpg
Andi
Originally posted by owelly
I bought a cheap, but CE marked, polystyrene child seat from Makro for £15. I took the cover off and trimmed the polystyrene so it fitted tightly into the fibreglass seat and put the cover back on. When belted in and the straps adjusted nice and tight, my boy was more secure then he ever is in the ISO-FIX seats we have in out tin-tops!
