Hi All,
Im struggling to find harnesses that meet my criteria.
- 5 or 6 point
- Red
- does not need to be FIA approved, car for road, trackday, and maybe a hillclimb or sprint occasionally
- Not massively expensive (looking at around 120-140 each hopefully)
- Short type, for single seater/locost/westfield/caterham type seating/mounting points
- clip on type mounting
- twist to unlock latching mech
- ideally 3" straps
Any thoughts, recommendations, comments?
Am I asking too much for my budget?
http://www.demon-tweeks.co.uk/motorsport/harnesses/trs-pro-6-point-single-seater-harness
http://www.demon-tweeks.co.uk/motorsport/harnesses/schroth-clubman-ii-6-saloon-harness
Try Prima Products, the 5 point is here and
the 6 point is here. They meet your spec and
are within your budget
They also do 'custom' for the same price/ very little extra if you want different lengths etc
Nothing to do with me other than a very happy customer, will be ordering another set from them in the future for my new car
We supply these if required.links below
http://www.kitcardirect.co.uk/titon-5-point-iva-compliant-fia-8853-98-approved-racing-harness-standard-adjuster.html
http://www.kitcardirect.co.uk/titon-6-point-iva-compliant-fia-8853-98-approved-racing-harness-standard-adjuster.html
One is the 5 point the other the 6 point harness, great quality harness,
any questions we are happy to help
KCD
Thanks for the replies
It appears the Schroth Clubman II might be the best bet. The Titon 6 pointers dont have the clip on mountings unfortunately.
The titon harnesses can be made with either clip on or with anchor plates,
You just let us know what you want and its made,
You could be strange and have some anchor and some clip on
its made to what you want if that helps,
KCD
http://www.racerpartswholesale.com/category/GForceCamlockHarnesses
US$155.
