Hi All, I'm working on a design and it involves the seatbelts being mounted inboard (centre of car) rather than mounted outboard (sill side).
I've been in a production car that has this ( can't remember which one though, old 80's I think?!) but wondered how this related when
it came to the IVA? I've looked and there is no mention of which side it comes from as lang as there are belts. I'm planning on having a
nice bit of structure around the centreline of the car so will have no issue strength, just wondered if anyone could shed some light if it would be
possible please? Thanks in advance.. J
Thats how Westfield have the inertia belts mounted
Although looking at the way you have the belt routed there will be no inertia locking! the belt needs to exit the roller vertically (or however is was intended to in the donor) for the locking mech to work.
there was a thread about this earlier this week
http://www.locostbuilders.co.uk/viewthread.php?tid=199648
edit: also the inertial reel must act on the over shoulder part of the belt, not the lap.
[Edited on 12/8/15 by gremlin1234]
I was going to do it that way, but thought that the driver/passenger didn't have as much security, from being thrown out sideways, as they did
with the belt coming over the outside shoulder.
I have fitted the reel on the floor behind the seat, the belt going up and through the guide in the same position as the harness would be.
Originally posted by 40inches
I was going to do it that way, but thought that the driver/passenger didn't have as much security, from being thrown out sideways, as they did with the belt coming over the outside shoulder.
The seat belt reels in the MGF are mounted on the rear shelf with the inertia action working horizontally. Obviously you would need the strength in
the chassis to mount it there but it gives an option.
Other makes may be available.
This was my first idea, but now I'm putting my seats in I don't have enough clearance behind them. I'll lose at least three inches of legroom if I put it back there.
E36 BMW coupés had these in the back seats, the reel built into the folding seat locking mechanism. Should be easy enough to adapt?
[Edited on 12/8/15 by blakep82]
The reel fits nicely into the curve of the GRP shells, the seat will go back until it traps the belt against the bulkhead.
it's possible to get reels that are adjustable for different positions.
see
http://www.rimmerbros.co.uk/Item--i-RB7355SA
Even though it may be possible to install with Inertia Reels inboard, I would prefer not to.
This because I think that during a roll over Centrifuge (sp?) force may cause you to slip under the shoulder belt.
But that is just me...
Hope this point of view gets analyzed by someone with higher knowledge.
AA
AA
Fantastic, great reply's, thank you... So it's fine for IVA then which was my main concern.. Thanks again..
