I built my Tiger Supercat over 10 years ago now and it's due a bit of a refresh I think.
It's been a long time since I actively looked at parts or got involved with the Kitcar world so please forgive any naive questions.
I love the look of the newer Caterhams and would like to make my dash look similar. For me that would mean buying the carbon fibre dash itself,
switches and lights.
Can anyone help me track down the parts used?
I know lots of people make these flick switches, but usually they have horrible nuts and poor finishing a the base. Caterhams look lovely with these
smooth finish.
Any idea what these hoops are called? (Toggle Switch Guard?)
Thanks.
[Edited on 19/3/16 by joedredd]
Cheapest from the U.S.
Classic U Shaped Toggle Switch Guards Black Anodized Aluminum
Nice quality switches
http://www.polevolt.co.uk/acatalog/Apem_Toggle_Switches.html
Classic U Shaped Toggle Switch Guards Black Anodized Aluminum![]()
It may be worth sending rosco86 a pm. I'm sure that's what he has done.
Failing that the bmw mini's use the same kind of switch block on the dash so you maybe able to retrofit that.
Mini switches are not regular switches. They use some crazy sort of logic as they do multiple functions. Someone on here did manage to make them work, but I think it was a lot of faff!
CBS do them, but they are eye wateringly expensive
Actually! Looking at the ones from the States, they are about the same price!
[Edited on 19-3-16 by 40inches]
There's a book by Brian Thompson called "How to Build Your Own Supercar"
https://www.bookdepository.com/How-to-Build-Your-Own-Supercar/9781845841669.
It's full of useful tips and tricks for car building, one of which is his cheap method of making toggle switch hoops. He used small stainless
tube, bent into half circles with a brake pipe bender, then expanded a rivnut inside each end of the resulting hoop. Fixing was by screws from the
back of the panel.
Food for thought perhaps?
Edited to add a pic of the page in question. For some reason, LocostBuilders is choking on the URL for this image - no idea why
[img]https://lh3.googleusercontent.com/-U_GC2xk8RnE/Vu4xrN31giI/AAAAAAAAY7M/nBs4WgxB5sMeis8AkhBdV1htgkXst4WgwCCo/s800-Ic42/IMG_20160320_150848.jpg[/im
g]
Dominic
[Edited on 20/3/2016 by TheGecko]
I used a me mini switch panel and just replaced the switches with normal toggles.
Excuse the dust
Why not just use U bolts for the hoops and hide the fasteners in a recess? Could probably powder coat them black if you really wanted, or just use a
decent paint.
Switches are relatively easy as they just look like standard toggle ones, the only issue may be getting round surrounds; they just need to be spaced
back so the thread doesn't protrude.
For the warning lights why not just use something like Dash Warning / Indicator Lights Round 12v LED - Brake / headlight /
sidelight and put the stickers on?
[Edited on 20/3/16 by Badger_McLetcher]
cheap method of making toggle switch hoops. He used small stainless tube, bent into half circles with a brake pipe bender, then expanded a rivnut inside each end of the resulting hoop. Fixing was by screws from the back of the panel.
For the warning lights why not just use something like Dash Warning / Indicator Lights Round 12v LED - Brake / headlight / sidelightand put the stickers on?
