Hi to you all.
Sorry it's been so long since I last posted, can't believe it's been 2 years!!
I read your posts all the time and really enjoy them, but I struggle with 'media' issues so find it difficult to post myself.
I've had so much fun with the build - best fun I've had with my clothes on. Had loads of issues as you can imagine with the cvh engine, and
it's still running like s--t.
However, it does run on a few cylinders and I finally took it to Derby for its Iva last week.
The tester was really helpful, I think he enjoys testing these things as much as we like building them.
Headlights were a bit out of alignment but he let me adjust them and passed them after a few minutes.
My declared weights caused a few issues but he said that they would be ok on a retest.
The outside edge of the seatbelt anchor bracket was not radiussed to 2.5mm so that was a fail.
He wanted to look at the seatbelt anchor fixing to the chassis, so moved the drivers seat forward on the runner to have a look. The bolts on the back
of the seat to runner were loose, and as we moved it the one bolt fell off!! What a complete plonker I am. The bolts had to be loose to locate the
bolts to the floor, and I must have just forgotten to tighten the driver side nuts afterwards.
Easy to sort those and I was so pleased because I thought there would be so many other issues.
However, big fail was on the brakes. He noted that the brakes were 'a bit spongy but effective' I've bled them 5 times but can't
seem to get them any better. But that was not a fail, just a note.
The major fail was on brake/weight distribution calculations. It passed on pedal pressures 1-3, but on p4 ad p5 it went the other way.
I can see that it's all to do with brake bias but I can't see how to correct it.
I've taken the brake deceleration valve off the sierra and may try to fit that as it's a brake bias control, but I understand that it's
a live valve and the test is static, so that's not going to sort the problem but may help. Other than that I'm hoping to get the car on a
track and give it a few miles in the hope that the brakes will bed in and that may help.
Any other thoughts would be very much appreciated.
Sent from John's iPad
For the IVA test I replaced the sierra rear wheel cylinders which are 2.2?cm dia with Ford Ka cylinders which are 1.7cm dia but theoutside housings
are identical. No issues at all at IVA with balance - er then they fell off and the sierra ones went back on.
Because they are smaller dia they exert a lesser force on the brake shoes and there fore prevent locking up but allow a reasonable amount of braking
to take place
Good luck with your retest
John;
If you want any help correcting your brake bias U2U me. I do this stuff for a living (for a large vehicle manufacturer) and I'm always happy to
help.
Ian;
If you really switched the rear drumbrake wheel cylinders back to 22.2mm bore after IVA then your rear axle may lock before your front axle during
some high deceleration brake stops. It may work perfectly well at low to moderate rates of deceleration but at higher values the rear axle will lock
before the front axle.
When/if that happens your car will spin out of control. Be very careful
Originally posted by JAG
John;
If you want any help correcting your brake bias U2U me. I do this stuff for a living (for a large vehicle manufacturer) and I'm always happy to help.
Ian;
If you really switched the rear drumbrake wheel cylinders back to 22.2mm bore after IVA then your rear axle may lock before your front axle during some high deceleration brake stops. It may work perfectly well at low to moderate rates of deceleration but at higher values the rear axle will lock before the front axle.
When/if that happens your car will spin out of control. Be very careful![]()
Ian,
Thanks for the speedy response, and what a brilliant idea. I’ve been down to my local Andrew Page and they found one for me to check. They can get the
other one in tomorrow, so for £12.00 I should be able to get that done. A bit more bleeding to do, but fingers crossed.
Justin,
Thanks for the offer, and you’re not too far away from me. It sounds like Ian’s trick should work, and I’ll take your advice and leave the smaller
cylinders on afterwards.
Any advice on the bleeding? I’m using the air-fed easybleed and starting at the furthest wheel, but even after doing it 5 times the pedal is still
spongy. Maybe after changing the cylinders I may have some luck.
John
Assuming you have drum brakes... Bleed the rear with the adjusters fully off. When they're adjusted, a small amount of air can remain in the end of the cylinder due to the slight angle it sits at. Alternatively bleed as normal then remove the drum, open the bleed nipple and push the pistons fully back with a couple of screw drivers, then lock the bleed. Repeat on the other side. Note this needs 3 hands.
Have you manually adjusted the rear brakes? Is the auto adjuster free and operating? After fitting your new rear wheel cylinders slacken off the handbrake adjuster then with the brake drum off operate the auto adjuster one click at a time refitting the drum each time until the drum just fits without binding . Refit the drum then readjust the handbrake
If it still takes it is possible to convert a automatic brand restrictor to manual, hunt the web. If you can't find anything u2u me and I'll hunt too. I think fiat Uno rings a bell for done reason.
Nick,
I'm hoping that the Ka cylinders will do the trick, it only took 1 hour to fit them, so could be a great result. But if that doesn't work
I'll be looking at all of the other options.
Is Iva different from Eva, as note 4 clearly excludes manual bias valves. Or does inaccessibility rule?
'Note 4: Hydraulic valves that only operate automatically and react to vehicle loading or braking forces are permitted (Load Sensing and Gravity
valves) Manually adjusted valves (other than to permit presetting the automatic function of a valve) are not permitted to be fitted even if they are
rendered un-adjustable.'
John
Obviously I meant SVA. Predictive text rules!
John
OK the rules appear to have changed!
SVA was quite some years ago for me and I've not had to IVA a car so not familiar with current the rules. I'm sure for SVA you were allowed
adjusters, but weren't allowed to adjust the bias from the drivers seat. I believe others fitted twin master cyclinders with adjustable bias
bars, but "modified" them to be unadjustable so their cars would pass the SVA. It seems the IVA has ruled this out.
I hope the Ka mod works for you and you get through the test!
Thread resurrection!...How did you get on with the brakes in the end, did it pass ok? Just curious as I’m looking into options on mine at the moment.
Abe,
Seems like ages ago now!
I fitted the Ka rear cylinders in no time booked the retest. When I arrived at the centre the tester said that the brake equipment wasn't working
and he would have to do a manual test. This involved me driving the car towards him and hitting the brakes on his signal. The front brakes locked up
first so he said than was ok, passed.
The brakes still feel spongy, but are quite effective and there is no sign of creep, so all ok.
I hope this answers your question, and nice to hear from you.
John
Good stuff! Thanks for the reply John.
Got an amusing picture of you running over the tester lol
