I think I already know the answer but...
My lap belt (on the tunnel side) is being deflected by the side of my GRP seat when I'm sitting in the seat in the belts done up as tight as I
can get them. The deflection is very slight, I think if I was a bit fatter, or wearing thicker clothing, it would not make contact!
But I take it this will be no good for IVA?
I've got no evidence to suggest the seat is strong enough to take the forces required for it to be structural. Although my body moving forwards
lifts the belt *away* from the seat, I appreciate it could be different in a side impact...
Does the belt not come through a hole in the seat?
You could take some material from the side of the seat, but you may be ok fitting large smooth edge trim at the contact point?
You can see how much I took off in these photo's
I think most low sided seats have the same contact with the lap belt and a lot of high side ones with holes probably do as well. I've not heard of any IVA failures because of it. They're more concerned with top mounts.
