Hello,
As the title says- has anyone passed IVA with a rollcage mounted centre mirror and what make did you use? I have been using a longacre for trackdays
etc but the radi on the mounts is a no go. Maybe weld up my own mounts?
Thoughts please,
Josh
Take some rubber U seal and cut one leg off, loosen the bracket, tuck it under then tighten up. I passed with it like that.
Remember its checked in a forward direction only, so providing the fittings are behind the mirror they would not be contactable by the 165mm sphere
Awesome! I can't remember if the centre mirror needs to be adjustable, but clearly not!
