Lately I've been thinking about changing my 4-point harnesses to conventional inertia lap-and-diagonal types. Various reasons for this,
including:
and it describes how to fit this kinds
of belt to their cars. I would probably follow their guidelines if nothing else looked better)
Last year I was involved in an accident when my Haynes Roadster was written off. I had 4 point seatbelts fitted. Because it was cold I was wearing
more clothing than usual and it was a real pain to get the belts closed so I was really tightly strapped in. 45mph on straight road in torrential
rain my car aquaplaned and I hit the hedge and ripped off the left hand corner of the car.
Two things.
I am so pleased I was wearing more clothing that effectively tightened my belts more than I would usually have. It saved me a lot of injury.
I am so glad I didn't have the lap and diagonal belts fitted to friends Westfields, I would have been seriously injured in my accident.
Your choice, I know what mine would be.
Hi,
I had to change back and forth from 4 point harnesses to regular seatbelts because of the different inspections and change of country.
I bought the inertia ones from CBS, the ones you can fit the rolling unit in any position (vertically or horizontally), with the long stalk. I first
had the short stalk ones, but the stalks were really too short and very hard to find when you wanted to buckle up.
https://www.carbuildersolutions.com/uk/securon-multi-angl
e-retractable-long-stalk-black
I used 3 of the 4 attach points of the harnesses. On the Haynes, upper attach points are on the roll bar, so the rolling unit of the seat belt is
installed on the inner points. Outer points were not possible because too much "behind" the seat. I blanked them with a bolt, and a bolt
head cap. So the diagonal strap is the other way around than on conventional cars.
A more aesthetic solution would have been to fit the rolling unit on one of the lower point, but there was not enough room there for achieving
that.
Here are a few picture of the set-up:
It does nor look very good, but it does the job.
Hope that can help
Some answers in this thread https://www.locostbuilders.co.uk/forum/24/viewthread.php?tid=212907
Originally posted by voucht
Hi,
I used 3 of the 4 attach points of the harnesses. On the Haynes, upper attach points are on the roll bar, so the rolling unit of the seat belt is installed on the inner points. Outer points were not possible because too much "behind" the seat. I blanked them with a bolt, and a bolt head cap. So the diagonal strap is the other way around than on conventional cars.
A more aesthetic solution would have been to fit the rolling unit on one of the lower point, but there was not enough room there for achieving that.
Hope that can help![]()
I donīt thik this arrangement would be of any help if you are rolling in the car...
As you may slip outward under the inner side shoulder belt.
This is only my point of view based on uneducated assumptions.
I will be using 4 point harnesses.
