Any recommendation for grp seats for a Phoenix . I will be using a 4 point harness. Anyone have some second hand ones lying around?
Regards, Jon
The Phoenix and Striker are very narrow so a lot of seats won't fit. JK Composites do a specific seat for them.
Tillet do a narrow set that suit if you have the $$$.
Think they are called the 3.5 (as they are 35cm wide.)
[Edited on 3-7-21 by loggyboy]
And JK Comps are apparently had to get hold of.
Good luck with it. I'm down to one JK Comp ( I think) which come with the car.
Holy thread resurrection Batman
I'm on the lookout for some striker bench seats to get through IVA here.
Failing that I going to go for some buckets, which is the end game anyway.
JK Composite seats seem to be the recommendation by most people. Does anyone have any recent experience of buying from them?
Another option could be a 350mm wide version of these on Ebay
seats
Looking for some help or recommendations please.
TIA,
Ian.
I have ones that look very similar to the ones in your eBay link. I suspect they are the same, but I got mine second hand.
They are in my Stylus, which I believe is equally small and narrow.
I put edge trim round them and they passed IVA without problem (and I think the edge trim makes them look neater). They seem very comfortable from the
limited amount I’ve used them so far.
[Edited on 27/10/22 by wonderfulweasel]
I put edge trim round them and they passed IVA without problem (and I think the edge trim makes them look neater). They seem very comfortable from the limited amount I’ve used them so far.
