Seat foams seem to be scarce for the MK1 and I wondered if seats from a later model for which foams are available are a similar size and fit the seat
slider mounting of a MK1. In other words, are they interchangeable?
Thank you
John
The floor pan is the same from mk1 up to mk2.5 so should be a direct swap. Lotus Elise seats are a common upgrade from mk1 seats also.
The seat belt stalks on the mk2 models bolts to the runners whereas the mk1 has the stalk on the tunnel - other than that it should be straightforward
Yes the connectors on the belts are the same between mk1 and mk2 (some of the very late mk1's had the stalks on the seat frames like the mk2 / mk2.5) - its only on the mk3 that they differed.
