Ply thickness for seats.
Dale - 4/2/05 at 06:26 PM
I have finally admitted to myself that I will be going with the seats as in the book. Tested to see that my wife can reach pedals and steering wheel if I put a booster cushion behind her.
What thickness of wood sheet are you using behind the foam for the seats?
Dale
flak monkey - 4/2/05 at 06:55 PM
It doesnt really matter, as long as its reasonably rigid and thick enough to staple to/bolt to the chassis. Would have thought 8-12mm would be about right.
britishtrident - 4/2/05 at 07:57 PM
The plywood dosen't need to be very thick but you will need to add beam strenth by using battons particularly at the top Lotus Seven back rest was actually adjustable --- too crude for words typical Chapman minimalist.
