Following up a response to a point I raised in the GTS section,
Can anyone confirm that it is acceptable to apply a 19mm radius to the bottom of a dash for 90 degrees? I was under the impression that I would have
to allow a greater thickness at the lower edge to allow the radius to return and avoid being contactable by the examiners 'balls'
Thanks Mick
I would presume this is correct...
Err...... which bit?
Mick
