I've been looking around for some replacement 4-point harnesses for my car, and it's raised a question - most 'clubman' belts are
marked as Westfield or Caterham. What's the difference?
I believed that I would need the Westie-sized ones, but now I'm unsure... anyone know? (my belts fasten to the roll-bar, BTW).
cheers,
David , have you looked at the Sabelt range ? around £45 per set and in different colours. They fit my car OK but could do with some means of stowing the slack on the shoulder straps
Surly the odd mil or two doesn't flap around does it?
Paul G
I think the difference between Westfield and Caterham belts is the fixing method.Caterham bolt in and the Westfield ones use the untidy looking spring
catches.
I have Luke 4 point caterham type belts and they have the reverse type adjusters but push latches, I also fancy changing to 5 point harnesses with the
aircraft type buckle due to the difficulty getting into them without releasing the adjusters.
Paul.
Paul (G) , some of us are not as big as others, so we have a little slack to tuck away. end of strap hit me in the eye once, not funny at legel limit.
i've just bought these securon harnesses, they retail for 170 each i can get them for 220 a pair posted if you're interested. 3"
shoulder straps, just cut the excess off and take them to a sewing shop to get them edged!!
Both Westfield and Caterham Harnesses have bolt fixing for the side straps, Westfield uses eye bolts for the rears, Caterham use bolts.
Hope that helps
Marcus
Forgot to add, both have reverse acting side straps.
[Edited on 17/12/05 by Marcus]
marcus is correct
Someone on the Se7ens list (forget who
) is organising a Willans harness bulk-buy.
5 points might be beneficial as they stop you 'submarining' in a front-ender!
I'd have bought them if I'd realised how much the 4 point's lap straps rise up as you sit there. Going from safely across the hips to a
nice eviscerating position under the rib cage!
Mark Allanson would be good to talk to on this as he has seen a lot of car accidents*!
James
*I believe that's seen not caused!
It looks like I'm going for a set of Luke 'Pro' belts, once the bloke in Ipswich tells me the price! (roughly £70 - £80 each).
I'll be starting with 4-point, as I reckon being able to tighten the lap strap properly should stop it riding up - all the fixing angles on my
car are correct, but a loose lap belt will ALWAYS ride up when you tighten the shoulder straps. These belts have the option for adding the 5th belt
if I still feel the need.
I'm still worried about the family jewels if I crash while wearing a 5-point harness, though...
cheers,
Sorry David , didn't see previous post . I know what you mean about adjusting lap belts , A real pain . Not sure about legality about turnbuckle release though?
I'd have bought them if I'd realised how much the 4 point's lap straps rise up as you sit there. Going from safely across the hips to a nice eviscerating position under the rib cage!
James
*I believe that's seen not caused!![]()
If the buckle has the option to accept five harness clips then you can convert it to a six point harness by using two attachment points for the crotch
strap terminating at the same point at the buckle. Much more user friendly
Mick
