MK indy
1, do you bolt the seats direct to the floor?
2 where best to get an expansion tank and what type
3 need a dash, make my own or where to but a flat dash with radius
4 wiper motor, buy new or donor where from?
5 mirrors what type where from ?
Dash with radius......... Mr Triton.
Carboniferous even
Wiper motor........not from Mr Triton,but a Mini. Get the wheel boxes and the bendy bundy tube thing and shorten it if necessary.
I fitted one to my Robin Hood back in the mists of time and the motor I used was from an old,old mini with one arthritic speed. Perhaps the newer old
minis had slightly more vigorous goings on.
HTH
Mirrors ....Honda fireplace
Gosh,aren't we helpful.
Seats.....best bought from Mr Triton. Bolt through the floor with a nice big washer to spread the load. Nearly typed thighs then,can't think why.
Perve
1. you can do if you can get them to bolt through the bars. i couldn't see much with glassfibre seats bolted to the floor. i'm not exactly a
giant. runners and spacers lift it an inch and a half, and allow 'stuff' to be put behind the seat then slid back
2. rover 400, the last of the wedge type ones are common use for most. i got mine from a '95 416. filler suits pinto water pump, and small
breather suits rad breather or t/stat breather (see pic)
3. make your own dash if you think you're up to it. fake carbon looks shocking, real carbon is real pricey, and it's too big a panel in
thinnish ABS not to distort when gauges are put in. i used 6mm mdf, triple thickness for bottom edge, then rounded over with router. holes cut, then
covered with upholsterers vinyl, NOT MARKET CHEAPY STUFF, it doesn't stretch enough and in all directions.
4. wiper motor should be your right arm, powering your right hand to wipe glasses/visor. driving in the wet is bad, and best avoided, but it's
not worth putting a screen and weather gear on just for those 'what if' moments imo. if you desperately want to, speak to mookaloid.
he's got the nicest screen set up i've seen about.
5. mirrors are largely personal preference, but honda cbr600 replicas seem to be popular, posibbly to the point of being a bit common. for a stripped
out style car, spa mirrors look the part, but you'll need hooj ones for sva, that and their sharp edges. for a trimmed one, i think the ones
tiger supply with the avon look well, and give a damn sight clearer view of the road behind than the SPA formula mirrors i had did. having said that,
if ever i needed to see behind, i used the rear view mirror or looked over my shoulder.
and at that juncture, i'm off to bed
hth
tom
