hi,
i have a pair of willans Super Sport 4 x 4 harnesses with eye bolt fittings at the top and standard bolts at the bottom. i have the eye bolts for the
top but the belts didnt come with bolts for the bottom or any of the "tophat" washers.Looking at the belt a standard bolt will not fit
through the hole with one of the "tophat" washers. does anyone know if willans have special bolts if so who supplies them?
Cheers Tom
As far as I know, willans use standard 7/16" unf bolts.
Go to a scrappy, virtually any production car uses the same. (and the top hat bits)
Marcus
