how have you fitted your roll bar? what type of bolts etc.
its a indy if that helps
I think i used M10 round headed bolts.
3 m10 button heads in each foot on mine. 2 on the inside corners, and one in the middle of the outer edge.
hth
tom
If you are considering entering any motorsport/sprint/hill climb events then you will be well advised to get a proper roll bar with a diagonal and
backstays to RAC standard. - Welded on!
Mark
got mine welded on by MK when i bought the chassis
The bolting of rollbars is a worry, I'd weld every time.
Bit of a bugger if you've got a powder coated chassis though!
Mine's a standard MK, with harness bar and boot stays welded on.
Still class it as purely cosmetic though, there's no substitute for an RAC spec bar.
Marcus
i've welded mine on as i feel it looks better than having bolt heads showing
