Sierra handbrake cover..
Jumpy Guy - 19/4/06 at 09:20 PM
my handbrake cover is the rigid plastic standard one. I bought a new leather gaiter for it-
how do i get the standard handle and plastic guard off?
it doesnt seem to have any fixings....
fesycresy - 19/4/06 at 09:22 PM
Pull and twist, put some effort into it
RazMan - 19/4/06 at 09:24 PM
I took a pipe wrench to mine - that shifted it
Jumpy Guy - 19/4/06 at 09:38 PM
pull and twist what? the handle?
how do i get the plastic guard offt the lever?
RazMan - 19/4/06 at 09:46 PM
Just to clarify - Are you removing the plastic sheath & button to fit an aftermarket one like this? [shield your eyes] Rescued attachment handbrake.jpg
wilkingj - 19/4/06 at 09:46 PM
pull and twist the plastic hand grip bit on the handbrake lever / handle.
Its just a tight fit.
indykid - 19/4/06 at 09:49 PM
i clamped the lever in the vice, then used the open end of a biggish spanner and hammer to belt it off.
just a different approach, but yes, it's just a tight fit.
tom
Jumpy Guy - 19/4/06 at 09:50 PM
bling!!!
yeah, ive got the standard handle bit, which i need to remove
But
the rest of the lever is covered in a big plastic shroud, which im assuming i need to remove to fir my new leather gaiter?
RazMan - 19/4/06 at 09:57 PM
[bodge mode] If you are really sure you don't want to refit the old cover, hacksaw down one side to loosen it and just wrench it off with a pair of pliers.
tom windmill - 19/4/06 at 10:12 PM
Its very tight, just pull and be careful
indykid - 19/4/06 at 11:32 PM
istr mine hinged on a plastic rivet, although that may have been one of the other handbrake levers i tried before settling on the p6 one.
either way, a big screwdriver, and a saw of some sort will shift it.
tom
stevebubs - 20/4/06 at 12:32 AM
Is it possible to do similar to a Mk II escort handbrake handle?
Bluemoon - 20/4/06 at 08:58 AM
I have the same problem. I would like to know if I remove the pastic rivet and cover, will this effect the mechanics of the lever?? (I will keep the handle an button)..
Dan
Ian Pearson - 20/4/06 at 09:46 AM
Where did you get the gaiter from?
Jumpy Guy - 20/4/06 at 11:38 AM
got it at detilng, cant remember who from....
main question is - if i hack the plastic cover off, will it affect the operation/action...
